Results 1 to 1 of 1
Thread: Walls disappear when exporting to .dwg
    2012-10
    Default Walls disappear when exporting to .dwg
    In my Revit 2012 project I have several views set up that I use to export .dwg files. On one (and only one) of the views a handful of walls are no longer showing up in the exported file. There appears to be no logic or pattern in the problem - some entire walls are missing, some have small pieces missing, and others are fine. It seems like most of the missing walls are of one or two types, and I can't find any properties that are different for those missing walls. I've tried restarting and duplicating the view, and neither worked. Any ideas?
  1. 2011: Walls disappear in ACA Animation
    By rkc in forum ACA General
    Last Post: 2013-02-04, 04:43 PM
  2. 2012: [Help] AEC Walls disappear in 2d, Appear in 3d. Sometimes.
    By invaderkyle in forum ACA General
    Last Post: 2012-04-17, 11:03 PM
  3. Walls Disappear?
    By Tyveka in forum NavisWorks - General
    Last Post: 2009-06-17, 01:17 PM
  4. Embeded Walls Disappear
    By NKramer in forum Revit Architecture - General
    Last Post: 2008-07-28, 05:46 PM
  5. Why the walls disappear?
    By ricardo.o.maciel in forum ACA General
    Last Post: 2006-04-07, 11:21 AM
