Thread: Failed installation
    I could stop if I wanted to charliep's Avatar
    2003-02
    Northumberland, U.K.
    341
    Default Failed installation
    Downloaded the Building Design Suite Premium 2013 and have installed most of the products. However, Autocad Architecture, Autocad MEP & Aotocad Structural Detailing just refuse to install. The log shows error messages 1603 & 1619. I've tried several suggestions including clean install, logging on as administrator, disabling Anti virus, all to avail. Any reasonable suggestions will be most welcome.
    Regards
    Charlie Priest
    Enterprise Architectural Services Ltd.
    2001-12
    St. Louis
    5,221
    Default Re: Failed installation
    Quote Originally Posted by charliep View Post
    Hmm, thought I'd seen that mentioned before, another suggestion is to copy the install files to the hard drive, but, it doesn't look like that worked for this user.
    Is it also loading up the service packs to install? If so, have you tried excluding the service packs and installing just the base software?
    2003-02
    341
    Thanks Melanie, I checked the link you gave me and an interesting point about having another Autocad 2013 allready installed. I might try a custom install to a different directory.
    Regards
    Charlie Priest
  1. Command Failed
    By MTristram in forum Revit Architecture - General
    Last Post: 2010-03-04, 02:23 AM
  2. Run Failed
    By abechard in forum Green Building Studio - General
    Last Post: 2009-12-28, 09:05 PM
  3. Seek failed
    By E-Key in forum Revit Architecture - General
    Last Post: 2009-12-21, 07:43 PM
  4. Replies: 2
    Last Post: 2006-06-30, 08:31 PM
  5. Failed Installation
    By jnj1502 in forum ACA General
    Last Post: 2006-05-10, 04:20 AM
