Thread: sheet set title block NOT updating in existing drawings but is for newly added sheets..HELP
    2013-01
    Default sheet set title block NOT updating in existing drawings but is for newly added sheets..HELP
    I have an existing sheet set created with drawings. I've updated the title block with issue date as well as a key plan. The title block is an xref and all looks good with the dynamic blocks set up. I've maintained the DWT file name. So far so good. But when I open the existing drawings, the title block is NOT updated to reflect the changes. However, if I add a new sheet, the title block is the updated version...Not sure what I'm doing wrong. Anyone have any suggestions???
    2001-12
    St. Louis
    5,408
    Default Re: sheet set title block NOT updating in existing drawings but is for newly added sheets..HELP
    Quote Originally Posted by kgerber352767 View Post
    I'm not certain if it's entirely the same, but, I recycle sheet sets heavily.
    Opening a drawing file for a new set doesn't cause the fields in the titleblock to update, I have to open the SSM, hit 'refresh' and then it will update. But, it stays updated once that is done.
    I've never been bothered to run a script through the set to automate that refresh, but, that's what I would advise others to do if the irritant is the same as what I've described.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. 2012: Updating a existing block
    By rbhazie in forum AutoCAD General
    Last Post: 2014-10-31, 04:26 PM
  2. 2014: Can I get a parameter to control a label on both my title sheet and other sheets?
    Last Post: 2013-11-14, 10:21 PM
  3. Updating Title Block Fields Using SSM
    By nogienugz in forum AutoCAD Sheet Set Manager
    Last Post: 2008-01-24, 03:23 AM
  4. Updating Existing Block Attributes
    By SteveBig in forum Dynamic Blocks - Technical
    Last Post: 2005-11-04, 01:58 PM
  5. Field in Title Block not updating
    By Grumpy in forum AutoCAD Fields
    Last Post: 2005-02-22, 10:13 PM
