Thread: Revit - Fill Pattern Help.....
    2011-03
    22
    Exclamation Revit - Fill Pattern Help.....
    So in AutoCAD (I know, bad thing to start with), we have a block for which we place "over" our 2d sound attenuators. It is basically a box that we can trace over the SA and it puts in the attached pattern at the right length and width, like a parametric element in Revit. Well, we have a Revit project with lots of sound attentuators and the Project Engineer wants this "pattern" displayed. The drafter doesnt know how to say no or not possible, so as the BIM Manager, I need to come up with a way to do it.
    Ive tried creating a fill pattern, adding a filter for the SA and adding a pattern to that filter and it doesnt work right. Works for walls and such, but not a piece of mechanical equipment. Either the pattern is messed up (creating using hatch22 which is a pain to use) or doesnt rotate with element even when "align with element" is selected for the pattern. I cant create a parametric fill pattern in the family either, Ive tried that as well. There isnt even an option.
    Ive also tried creating a pattern using a model fill pattern, attaching that to a material and assigning that material to the family but it doesnt display in plan.
    The drafter has created a detail group, copied that detail group around and modified it for each and every SA, which there are many and of different sizes. Not very ideal as it seems very tedious. There has GOT to be a better way to do that and I just cant think of it.
    2010-03
    Nashville, TN
    104
    Default Re: Revit - Fill Pattern Help.....
    You could nest a detail item with the pattern into the family and constrain to the plan view geometry. I think you may still have issues with the pattern alignment/orientation.
    2008-02
    15
    BCERCad12,
    I'm the guy that wrote hatch22. Can you let me know what problems you were having? Why did you find it a 'pain'? What would have made it easier?
    I think if you reply to this thread, I'll be notified. If you'd prefer, you can comment on my blog. It has a page just for hatch22. http://mertens3d.com/blog/?p=200
    Thanks for the feedback.
    gregory mertens
    2011-03
    22
    Quote Originally Posted by info.159673 View Post
    BCERCad12,
    Maybe Im just having a brain fart, but it isnt working very well for me. I took the linework from the DWG file, highlighted in and made the pattern. Learned later that the arcs dont work, so made those into lines. After I did that, hatch 22, totally blew those up and kept telling me my angles were bad. I really just need this to get wider and repeat in the "length"...not repeat like a normal pattern, so guess I am just going about it all wrong. It happens.
  1. Existing Phase Fill Pattern Revit 2008
    By jmarchese in forum Revit - Platform
    Last Post: 2008-08-17, 11:51 AM
  2. Color fill (Fill pattern) not updating
    By tonyisenhoff in forum Revit Architecture - General
    Last Post: 2006-10-23, 07:13 PM
  3. Cut fill Pattern
    By dpatera1 in forum Revit Architecture - General
    Last Post: 2005-04-21, 08:14 AM
