Results 1 to 10 of 11
Thread: Contours
    100 Club chrisr's Avatar
    2005-01
    Ballina,Ireland
    142
    Default Contours
    I have a survey drawing with contours on that I want to use for a 3D model. What is the best and most effective way to apply a mesh to the contours. I have tried to use Ruled surf, not very effective as the mesh over hangs the contours, so not giving a true contour. I have upped the surftab1 and surftab2. Any suggestions would be greatly appreciated.
    Chris
    2001-12
    St. Louis
    5,407
    Talking Re: Contours
    Quote Originally Posted by chrisr
    Chris
    Chris, if you'll tell me what program you're using, I can move this question to a more appropriate place to get you an answer quicker...
    thanks...
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2005-01
    Ballina,Ireland
    142
    Default Re: Contours
    Quote Originally Posted by mes0945
    thanks...
    Thanks, I have the contours in Architectural Desktop where I am trying to create a true formation of the land. The contours are made up of splines.
    2005-01
    Ballina,Ireland
    142
    How come there seem to be no replies to my question about the contours! I also found that a few weeks back, no replies.
    2001-12
    St. Louis
    5,407
    Lightbulb Re: Contours
    ~shrug~ might not be something people have to do a lot, so people might not know how to do it... (sorry, I can't help, I don't know ADT or contours) give it a little time, someone might pop on who knows something...
    Melanie Stone
    @MistresDorkness
    Technical Editor
    13,656
    Hi Chris
    Please do not take the following as some kind of personal insult, I am only offering the information to try and answer your query.
    The below snippet is taken from the Forum Etiquette area within the AUGI Forum Guidelines -
    <snip>
    Do not demand immediate responses. Forum members are volunteers and have jobs just like you. They answer messages as soon as their individual schedules will allow. Our members span the globe and may be in very different time zones.
    </snip>
    I realise you are not "demanding" a response, I am only trying to show that people (AUGI members just like yourself) will answer
    if and when they can. Please be patient and let members answer (if they can) in their own time.
    Thanks, Mike
    Forum Moderator
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Have you tried looking into mass elements? Since they're already plines, you most likely will be able to convert them to a mass element.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2002-09
    Madison, WI
    5,687
    I believe you want to use the drap tool.
    If you connect all of your plines, set the elevation for each and apply the drap tool I believe that's how you want to do it.
    2005-01
    Ballina,Ireland
    142
    I seem a bit lost. The "drap tool". What is this please.
    Thanks
    2015-12
    4,730
    Check out the attached screen shot from ADT help system. You want to use the Drape tool to convert your plines into a Drape Mass Element. This is part of the massing system of ADT. The help system in ADT should walk you through this process.
  1. GIS Contours
    By rschaff in forum AutoCAD Civil 3D - General
    Last Post: 2010-10-08, 10:08 PM
  2. Contours
    By spaynter08 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-03-27, 02:13 AM
  3. Contours
    By drafting.33933 in forum AutoCAD Civil 3D - General
    Last Post: 2008-10-28, 07:11 PM
  4. Not able to see contours
    By msanders.85217 in forum AutoCAD Civil 3D - General
    Last Post: 2006-05-04, 08:06 PM
