Thread: changing number of wires to 5 on a panel
    2010-06
    62
    Default changing number of wires to 5 on a panel
    Hello all,
    Does any one know of a way to change the number of wires in a panel to 5 in lou of 4.
    Thanks,
    Dave
    I could stop if I wanted to CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    392
    Default Re: changing number of wires to 5 on a panel
    Quick answer: Not currently possible.
    We report the Number of Wires in our Tags, so for 5W elements I have created a separate Tag Family (or it can just be a separate Type with some visibility controls) with a static value (text) instead of a label to force the "5W" info into the Tag.
    When it comes to Schedules, we have created a Project Parameter (Integer/Instance) named "FiveWire". in the Schedule, we add this field and hide it, as well as the Number of Wires field. Then we create a Calculated Value with the formula:
    if(FiveWire=5,5,Number of Wires)
    This way, if we enter a "5" under this parameter in the elements' properties, it will be displayed as having five wires.
    Corey D.Please let the saying "The only stupid question is the one not asked" not be seen as a challenge to defy it.
  1. 2012: Changing circuits, wires don't update
    By tkendrick858672 in forum Revit MEP - General
    Last Post: 2012-04-19, 10:53 AM
  2. Split up Number of Elements in Panel Schedule
    By drewj in forum Revit MEP - General
    Last Post: 2011-02-24, 07:55 PM
  3. Number of wires
    By baji-gal.ferenc in forum Revit MEP - General
    Last Post: 2008-01-03, 04:18 PM
  4. Changing revision number tag how?
    By Wagurto in forum Revit Architecture - General
    Last Post: 2005-09-21, 08:21 PM
