Hello,
I would like to be able to access BBserver2013 log files of ALL servers of the farm from one unique place and not by going onto each computer (by RDP or by my self) to each single c:\User\<username>\appdata\local\backburner to see why server is going wrong (as mostly it happens because people missed some UVW maps or moved/renamed some texture files)
I've searched into backburner.xml but haven't found any path in it....
Do you know if there is a registry value to change which could place logs of each BB server on a same network drive (where projects are) ?
This parameter is even more needed when BBserver is run as Windows Service !
Thanks
