Thread: Help! Tower Bracing Issue
    2013-01
    Default Help! Tower Bracing Issue
    I am attempting to create a fully flexible support tower module. So far it flexs well in length, width, and height. I have several dimensional instance parameters set up to handle plate sizing and workpoints. I also have several visibility parameters to allow for multiple column sizes and horizontal bracing types. I was unable to make structural members work for the horizontal bracing as the length did not want to flex, so I used extrusions. My problem is the diagonal bracing for each bay. I have tried structural members (length won't flex), extrusions (can't seem to snap the ends to any item that will flex them with the tower), and now I have sweeps in place. The sweeps appear to work very well when viewed from a parallel elevation, but when I look at them in plan they do not flex with the tower in that direction. When I try to constrain the sweeps to a ref. plane it gives me errors. I was hoping that someone could shed some light on my problem. I have attached the file and attemped to remove all extraneous parameters, but I might have missed a couple.
    Thank you.
    100 Club Silleke's Avatar
    2007-03
    147
    Default Re: Help! Tower Bracing Issue
    Hi,
    The bracing seems to be not associated with a work plane.
    This can be the reason why the brace is floating.
    HTH
    Silleke
  1. bracing
    By Katika in forum Revit Structure - General
    Last Post: 2009-01-05, 02:28 PM
  2. Structural bracing and architectural walls - display issue...
    By FWSchreck in forum Revit Architecture - General
    Last Post: 2007-11-20, 11:45 PM
  3. steel bracing visibitly issue
    By bskripac in forum Revit Architecture - General
    Last Post: 2007-11-07, 09:59 PM
