Thread: Mark ups obscure floor layout when plotted
    2010-06
    57
    Default Mark ups obscure floor layout when plotted
    I have been sent some dwf files with the request to plot them from one of our site offices.
    The mark ups have been done in Design Review. WhenI plot them to the required size the mark ups are hiding the floor layout behind it. Themark ups are areas of a building that have been shaded & a number to denote the status of an area.
    On the screen & in plot preview everything looks fine, but when plotted it's as if the "mark ups" have come to the front.
    If I untick the box that says show mark ups the solid boxes & numbers are switched off. I can unlock the mark up but is there anyway I can move it to the back of the drawing?
    Thanks for any help you are able to give
    2010-06
    57
    Default Re: Mark ups obscure floor layout when plotted
    Hi after much digging around on assorted forums I have found an answer so am updating this in case it helps anyone else.
    When setting up the print options choose advanced (probably bottom left) & tick "Turn Data into bitmap before printing"
    This then plots as it should. it is slower but seems to be the only answer.
    Quote Originally Posted by lesleys View Post
    Thank you for this reply!
  1. Replies: 625
    Last Post: 2015-04-02, 05:19 PM
  2. Floor Pattern Layout
    By Jun Austria in forum Revit Architecture - General
    Last Post: 2009-08-13, 06:09 PM
  3. Obscure variable
    By Randall Temple in forum AutoLISP
    Last Post: 2009-04-14, 07:40 PM
  4. Obscure
    By dzatto in forum ACA/AMEP Tips & Tricks
    Last Post: 2007-11-20, 08:53 AM
  5. Floor joist layout.
    By Paul P. in forum Revit Architecture - General
    Last Post: 2004-07-02, 12:27 PM
