Thread: Pdf drawing import into civil 3d
    2010-10
    Default Pdf drawing import into civil 3d
    I want to import a pfd to civil3d and be able to follow contour lines automaticaly
    I downloaded autocad raster 2013 but it seems not to work with a PDF.
    Active Member Novarese's Avatar
    2012-05
    55
    Default Re: Pdf drawing import into civil 3d
    No need to... "download" anything, man.
    1] convert your PDF to a bitmap format, with the free PDF X-Change Viewer
    2] vectorize automatically that bitmap by means of the free Wintopo.
    South Eastern US, exact location unknown
    1,376
    Open the PDF in Adobe reader, select all and copy or use the shapshot tool. Then in Civil3D with Raster Design loaded do a paste. You may need to scale and rotate/align the image but that method words for PDF format and allows the RD contour follower to work.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    Moderator BlackBox's Avatar
    2,499
    Quote Originally Posted by Novarese View Post
    ... How pre-tell would one use these 'free' applications without downloading them?
    "Potential has a shelf life." - Margaret Atwood
    2012-05
    55
    Quote Originally Posted by RenderMan View Post
    You did not catch the irony of those quotations marks around the word "download", sir...
    2,499
    I consider it to be a compliment, that I do not automatically assume others have illegally downloaded software.
    ** Edit to add - However, if that is the case here, I do appreciate your attempting to offer a legal alternative... That should be commended.
  1. Civil 3D question - import points from excel, coordinates and attributes
    By Hotrod50 in forum AutoCAD Civil 3D - General
    Last Post: 2012-03-02, 04:09 PM
  2. Import données GPS dans Civil 3d (how to)
    By dume.susini in forum Français - AutoCAD Civil 3D / AutoCAD Land Desktop / AutoCAD Map 3D
    Last Post: 2011-05-10, 02:56 PM
  3. Import dxf points in civil 3d
    By Jawwad Malik in forum AutoCAD Civil 3D - General
    Last Post: 2010-06-03, 12:37 PM
  4. import from autocad civil 3d
    By jledgewood in forum Revit Architecture - General
    Last Post: 2010-05-24, 04:01 PM
  5. Civil 3d - Windes import question
    By arak11 in forum AutoCAD Civil 3D - General
    Last Post: 2008-05-07, 05:05 PM
