Thread: Door Material
    2006-11
    somewhere
    112
    Default Door Material
    Is there a way to align a model surface pattern in a family (see attached)?
    I added a stone patttern to my door family and I want to be able to align it with my wall surface pattern.
    Thanks.
    2009-03
    Somerville, MA
    1,060
    Default Re: Door Material
    Create the line you want as a model line in the door family, with a instance parameter for the dimension of it from one side or the other. Then you could move that line in your project. If the dimension is set to 0 it lines up with the edge and effectively disappears. Or have a visibility instance parameter, too.
    2006-11
    somewhere
    112
    Thanks that worked although it would be nice if I could do the same with a model surface pattern. I tried but it did not work.
  1. 2014: Door - Frame Material parameter
    By david_peterson in forum Revit Architecture - General
    Last Post: 2018-04-25, 03:03 PM
  2. 2015: Creating a Yes/No parameter for Door Frame material for scheduling
    By gross695874 in forum Revit Architecture - General
    Last Post: 2015-03-31, 06:06 PM
  3. assigning a Material to my Garage door
    By sherflor in forum ACA General
    Last Post: 2009-02-28, 01:56 PM
  4. Scheduling Door Material with yes/no paramters
    By andymeyer50 in forum Revit Architecture - Families
    Last Post: 2007-10-01, 07:30 PM
  5. Match Door Color to Wall Material?
    By pwilson.112560 in forum Revit Architecture - Families
    Last Post: 2007-03-19, 08:04 AM
