Thread: New Glitch: Regions Won't Preview or Print Transparent
    2008-06
    4
    Angry New Glitch: Regions Won't Preview or Print Transparent
    Hi All,
    I'm drafting in 2D and usually I can turn the latest Region transparent and everything under it, including other regions will be visible. But tonight, although it looks okay in the drawing view, the preview and print out show the top most Region filled, in this case white, solid fill. Normally this would disappear after applying 100% Transparency Overide. The only way around it is to Bring to Front every object behind it, which is time consuming and tedious.
    Only one new Region is behaving properly i.e. allowing me to make it Transparent AND be visible in Preview and printout. A comparison of the Properties of the good Region to the problem Regions shows no difference in settings.
    Is there any reason what might be happening. Everything in this View is 2D so far.
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    621
    Default Re: New Glitch: Regions Won't Preview or Print Transparent
    So under properties they are all set to Background = Transparent or Opaque?
    2003-05
    East Walpole, MA
    893
    you may have graphics option as wire-frame. try shaded or consistent colors
  1. 2014: Transparent massing & Ambient shadows (Glitch?)
    By damo3 in forum Revit Architecture - General
    Last Post: 2014-05-08, 11:18 AM
  2. 2012: Viewport is transparent in print preview
    By philipdurban in forum Revit Architecture - General
    Last Post: 2013-09-24, 02:57 PM
  3. 2011: Setting Planting to transparent. Glitch?
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2011-12-12, 07:44 PM
  4. transparent filled regions aren't really transparent
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-11-30, 06:05 PM
  5. AutoCAD image preview glitch
    By nanna in forum AutoCAD General
    Last Post: 2005-02-02, 09:26 PM
Tags for this Thread
