Results 1 to 10 of 15
Thread: AutoCAD Color Index and RGB
    100 Club Kris.Keller's Avatar
    Rigby, Idaho
    106
    Question AutoCAD Color Index and RGB
    I am looking for a way to export the AutoCAD Color Index and its associated RGB assignment. Any help in this area?
    Thank you.
    Revit Mararishi aaronrumple's Avatar
    2002-02
    St. Louis, MO
    4,695
    Default Re: AutoCAD Color Index and RGB
    Quote Originally Posted by Kris.Keller
    Thank you.
    Try this:
    https://tsc.wes.army.mil/products/ts...utocad_RGB.pdf
    http://www.isctex.net/acadcolors.php
    I'm not sure how accurate it is.
    Rigby, Idaho
    106
    Quote Originally Posted by aaronrumple
    Aaron,
    Thank you. I have already visited those sites and they are not accurate.
    13,656
    Question Re: AutoCAD Color Index and RGB
    Hi
    Does the following thread help...
    Compare layer colors to pantone colors
    Have a good one, Mike
    Rigby, Idaho
    106
    Quote Originally Posted by Mike.Perry
    Hi
    Mike,
    That is in the right direction but as in that thread I have the same concerns as John.
    Kris
    6,397
    I don't think John understands. The ACI is an index. One ACI number, is composed of 3 parts, a red part, a green part, and a blue part. You can relate all ACI values to an rgb/pantone value, but you can't relate all rgb values to an ACI, since it only has 256 values and rgb has millions. HTH.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by Ed Jobe
    I think he understands quite well.
    The comment was about adesk choosing to put out a technical document which tells you you can use a range of numbers which acad will not accept because they are defined with values between 0-1 whilst acad requires numbers in the range 0-255.
    6,397
    I see what you're saying now. In the previous thread, you stated that ACI used 3 components, not RGB, which is what you meant. I remember this subject somewhere in a vb ng. I'll see if I can find it.
    6,397
    This subject comes up a lot. Here is a thread that gives you a 1:1 list. However, it in a vb function.
    6,397
    Just curious, why are you needing the conversion info? I havn't found a need for it in the work I do.
  1. AutoCAD Color Index (ACI) with RGB Equivalents
    By mooker16 in forum AutoCAD Civil 3D - General
    Last Post: 2020-03-06, 03:08 PM
  2. 2015: Need To Change A Color In The Color Index.
    By omorah in forum AutoCAD General
    Last Post: 2014-08-04, 11:43 AM
  3. AutoCAD Color Index: Index Color List
    By GreenMan415 in forum AutoCAD General
    Last Post: 2008-06-25, 05:36 AM
  4. autcad Color Index messed up
    By rjairath in forum AutoCAD General
    Last Post: 2008-02-25, 08:15 PM
  5. Index Color to RGB
    By bweir in forum Dot Net API
    Last Post: 2007-02-11, 01:43 PM
