Thread: Design Options in a 3D View and Annotation
    2011-02
    30
    Default Design Options in a 3D View and Annotation
    I am trying to help a coworker who needs to show a typical ventilation ductwork layout with three different terminal devices serving the system. Just to paint a picture one system will be served by VAV, one on a terminal coil, and the final option would be a some type of valving.
    I suggested using design options to show the typical ductwork, air terminals in the main model. Then create the three design options to show the different terminal devices. The problem I have is how can he annotate these 3D views with just descriptive text, e.g. pointing to the terminal coil and noting "TERMINAL COIL".
    2011-09
    Miami, Fl
    52
    Default Re: Design Options in a 3D View and Annotation
    If I'm understanding correctly, you would like to annotate a 3d view. To annotate in 3d you need to lock the view (little padlock with a house at the bottom of the screen next to detail level and the little rendering teapot). As for having text associated with a phase, it can't be done as it can with an model element, you would have to create three different views and annotate each one separetely.
  1. Add text, annotation, & marks to Design options and/or Phases
    Last Post: 2014-10-22, 07:32 PM
  2. Annotation in Design Options
    By Bobby C. Jones in forum Revit Architecture - General
    Last Post: 2006-08-17, 01:19 PM
  3. Design Options - View Properties
    By bmarler in forum Revit Structure - General
    Last Post: 2005-10-13, 02:14 AM
  4. View only design options
    By adegnan in forum Revit Architecture - Wish List
    Last Post: 2004-09-14, 12:01 PM
  5. Design Options Losing Annotation
    By mlgatzke in forum Revit Architecture - General
    Last Post: 2004-06-02, 10:00 PM
