Thread: Revit MEP Family is not showing up in ARCH Model
    2008-02
    Los Angeles, CA
    248
    Default Revit MEP Family is not showing up in ARCH Model
    Revit MEP Family is not showing up in ARCH Model?
    The architect is not seeing a family created in the MEP model...has anyone run into this problem before?
    Thanks,
    2008-03
    Pottstown, PA
    53
    Default Re: Revit MEP Family is not showing up in ARCH Model
    Some basic things to check. Is the element/catagory turned on in the architects model for that view? If it is modeled as Mechanical Equipment, are their visibility graphics turned on? Is the MEP model actually linked in their model?
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    What Category is the family? I assume you can see it in the MEP Project, so is it still visible if the View's Discipline is set to Architectural?
    It could be an issue of Workset (maybe it's on one that is off by default).
    Have you verified that the element's Phasing is correct?
    Are Design Options involved in the Project?
    Have they mentioned what they've done to try to correct this issue? Have they toyed with the View Range, V/G Settings, etc?
    2008-02
    Los Angeles, CA
    248
    Thanks for all the help.
    When I placed the family in the MEP model, I placed it under Shared Levels and Grids. And in the Arc Model they have our MEP shared levels and grids turned to Closed (or turned off).
  1. Replies: 1
    Last Post: 2015-06-09, 08:53 PM
  2. 2013: Ducts showing the linked arch model behind them as if they were transparent
    By jcolombe536338 in forum Revit MEP - General
    Last Post: 2014-03-02, 09:02 PM
  3. 2013: ARCH MODEL (FOR PRINTING PURPOSE) AS MEP MODEL (revit 2013)
    By HDC0NY in forum Revit - Platform
    Last Post: 2014-02-03, 06:03 PM
  4. Revit Arch 2010 - Generic Model Family Editor - Connectors
    By brenehan in forum Revit Architecture - General
    Last Post: 2009-07-08, 11:05 AM
  5. Working with Arch Revit Model's roof? I need it...
    By scowsert in forum Revit Structure - General
    Last Post: 2007-09-24, 05:37 PM
