Thread: Adaptive vault
    2012-12
    Minsk, Belarus
    Default Adaptive vault
    Hi
    I made this adaptive family for vaulted ceiling in the church. It works well but one thing disturbing - it has variable thickness on the sections/ 7 parametres regulate only vertical distance between the curves of top and bottom surface in 7 points. I need to add a formula that connects distance between points and return "normal" distance between curves. Thanks.
    Orlando, FL
    1,049
    Default Re: Adaptive vault
    Welcome to the forum. Is there a reason for modeling the thickness? I would model just the surface, and then, in the project, I would select that surface to create a wall or roof by face in the project. Adaptive points are not necessary, either. Simple reference points hosted by planes are enough.
    2012-12
    Minsk, Belarus
    Thanks for advice!
    Roof by face is what i need! Why i didn't thought about it before(
    I made points adaptive because the chapel with this vaults has irregular hexagon in plan; so every part of the ceiling has different projection.
  1. Replies: 0
    Last Post: 2015-08-07, 05:27 PM
  2. Replies: 0
    Last Post: 2015-08-07, 05:26 PM
  3. Replies: 0
    Last Post: 2013-04-17, 04:58 AM
  4. Connecting Vault basic 2013 client to vault 2012 server
    By eradityabjoshi in forum Vault - General
    Last Post: 2012-05-30, 08:05 AM
  5. Replies: 8
    Last Post: 2007-05-14, 06:44 PM
