Thread: How to create points on LHS alignment which are at even chainage w.r.t the main centreline alignment
    Unhappy How to create points on LHS alignment which are at even chainage w.r.t the main centreline alignment
    As subject.
    I want to create point along the LHS kerb at 5m chainage interval with reference to the centreline alignment.
    I created an imaginary illustration sketch below.
    Please help.
    Gary
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: How to create points on LHS alignment which are at even chainage w.r.t the main centreline alignment
    Are the points needing to be 5m along the centreline? You might try sample lines along the centreline at the desired interval. Of course, the placing of points would then need to be manually placed. There may be another way, but I don't place points as often as I should.
    2008-03
    Columbia/Jefferson City, MO
    224
    There may be a better way, but one way you could do this is to create points by "measure alignment" this will allow you to set up the distance you want between your points as they are placed along your alignment. BEFORE you do this you will need to make some changes to the Create Points dialog box, specifically under the Default Name Format > Point Name Template, change the starting number and increment value to what match what the distance will be between your points. so if you wanted to start with 5 feet your starting number would be 5 and your increment would also be 5 if that is going to be the distance between points. you can now execute create points by the "measure alignment" method, pick your alignment, pick your starting and ending station, specify offset and increment distance and your points will be created. if you are not seeing the correct labels, you will need to create a new point label style that has the point NAME included in the style. I hope that helps.
    Cheers!
    Mike T.
  1. 2011: Creating points with Alignment data
    By Chud in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-12-18, 02:30 PM
  2. Alignment Station label that is perpendicular to alignment
    By corboto in forum AutoCAD Civil 3D - Alignments
    Last Post: 2010-05-20, 10:43 PM
  3. assign centreline of alignment on ground slope
    By awong.221095 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2009-09-15, 08:40 PM
  4. Set MText Alignment Based on Pick Points
    Last Post: 2007-08-27, 12:32 PM
  5. Help with points along an alignment in 2006 Civil 3D
    By wilsonk in forum AutoCAD Civil 3D - Alignments
    Last Post: 2007-05-24, 02:45 AM
