Thread: Schedule - calculated value / calculated field
    2009-10
    6
    Default Schedule - calculated value / calculated field
    Hi,
    Using the ScheduleDefinition.GetSchedulableFields it is possible to iterate through the available (shared) parameters and add or insert (addfield or insertfield) them to the created schedule.
    However I wish to add a calculated value / calculated field to the schedule. This field does not show up in GetSchedulableFields because this field has to be added 'on the fly'. In the API there is a schedulefieldtype.formula member which suggest it may be possible to add a calculated field. Do you know how to add a calculated field because I am running out of ideas. Or is this not possible (yet)?
    Raymond
    2011-11
    Saint-Omer, Pas-de-Calais, France
    58
    Default Re: Schedule - calculated value / calculated field
    No, this is not possible so far. You can only know that a column contains formulas, but you have no access to them.
    2009-10
    6
    I was affraid someone might say that. In the meantime I will use a different approach by duplicating an existing schedule and modify the copy.
  1. Calculated field in schedules
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2015-04-16, 06:01 PM
  2. Calculated Value in Key Schedule
    By jon111712 in forum Revit Architecture - General
    Last Post: 2014-04-10, 01:10 AM
  3. calculated value schedule field
    By gdb in forum Revit Architecture - General
    Last Post: 2009-07-06, 02:47 PM
  4. Calculated Value Based on Text Field
    By breck.baird in forum Revit Architecture - General
    Last Post: 2007-09-21, 04:13 PM
  5. Calculated Field or Label
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2007-08-14, 06:19 AM
