Thread: Vertical Curve in Pipe
    2009-12
    42
    Default Vertical Curve in Pipe
    Desiging a force main sewer line...project engineer wants to add vertical curve to pipe to avoid existing utility conflicts.
    Anybody know how, or if, you can create vertical curves in pipe networks?
    Any suggestions for a work around?
    Thanks.
    Houston
    7,519
    Default Re: Vertical Curve in Pipe
    Quote Originally Posted by gleiper View Post
    Thanks.
    Pressure pipes available in C3D2013.
    Otherwise, I don't know any workaround.
    We still draw ours manually due to no real good solution.
    2008-03
    Columbia/Jefferson City, MO
    94
    Just as a suggestion, if you could get away with just drawing say the flow line of the sewer main you could use what some would call a road profile to get your vertical curve in there, but that could be more trouble than it's worth.
    Moderator BlackBox's Avatar
    2,383
    We generally draw outs as well... But for jobs that required significant directional drilling, I've used Profile creation tools with a Profile View to trace dumb line work as my top of pipe, then when the top of pipe has been layed out I copy it down the appropriate depth for my bottom of pipe.
    Not really beneficial if like we used to, use one profile view and labeled the profile elevations within our sheet's title block, but if you either generate multiple Profile Views, or one Profile View within each sheet depending on an appropriate Profile View Style (usually the elevations on side overlap), then the above suggestion works all as it too is data referenced and can automatically show up in all Profile Views.
    Depends on how you work.
    Separately, this reminds me that I need to continue working on my directional drill utility plug-in... I've been waiting to see Civil 3D 2014 (post Beta), before spending anymore time on it.
    Cheers
    "Potential has a shelf life." - Margaret Atwood
  1. Is there a way to trim a vertical alignment at a vertical curve?
    By adam.zampino477239 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2012-05-09, 05:25 PM
  2. Which Vertical Curve?
    By jacunningham in forum AutoCAD Civil 3D - General
    Last Post: 2012-01-05, 01:27 PM
  3. Vertical Curve Label Styles
    By mooker16 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2008-11-23, 05:08 AM
  4. Vertical Curve Labels
    By mooker16 in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-11-19, 01:32 PM
  5. Vertical curve labels
    By dfarris75 in forum Land Desktop - General
    Last Post: 2006-10-26, 06:58 PM
