Thread: File Format limitations to DWF
    2011-08
    4
    Default File Format limitations to DWF
    ACA 2012 on Win7We are having an issue with our subcontractors wanting CAD drawings from us and they are refusing pdfs. So I am trying to find a happy medium and am hoping that dwfs solve our subs issues. My question is: Will a dwf created in 2012 be useable in an older version of Autocad? like 2008? is there a file format limitation?Thanks beforehand for your help!Bridgett
    2012-06
    Minnesota
    51
    Default Re: File Format limitations to DWF
    Im not 100% sure on this, but I believe with DWG Trueview, you can convert newer versions of DWF's to previous versions. You can also do that with a DWG. But what exactly is the problem your subs are having with the dwg? If its just file versions. when you export your dwg, you can save it to previous versions.
    Earth
    9,804
    Other than DWF vs. DWFx, I don't *think* there are any version differences - at least until you go way back, like maybe pre-R2004.....
    I have found over the years that the best way to find out things like this is just to send them a test file and ask them to let you know.
    A lot of partners, clients, etc. I have seen don't know even what brand software their guys are using, much less what version, etc.
    R.K. McSwain | CAD Panacea |
    Earth
    9,804
    Quote Originally Posted by JonTheBIMGuy View Post
    ....I believe with DWG Trueview, you can convert newer versions of DWF's to previous versions.
    Trueview does not open or save DWF files.
  1. ifc file format
    By ind415913 in forum Inventor - General
    Last Post: 2012-03-07, 10:18 AM
  2. DWT File Format
    By JONatMOT in forum AutoCAD General
    Last Post: 2009-08-12, 12:19 PM
  3. Replies: 9
    Last Post: 2008-09-16, 04:19 PM
  4. .x file format
    Last Post: 2008-06-05, 02:56 PM
  5. Need info on image file limitations
    By jgratton in forum AutoCAD General
    Last Post: 2005-09-09, 05:18 PM
