I want to rotate a line by degrees, minutes & seconds, how do I go about doing this?
I have already changed the units I'm working in to degrees, minutes & seconds, but how do I then go about entering them in to AutoCAD?
Thanks in advance
Thanks in advance
Hi
Have a browse of the following threads -
Site coordinates...
need help drawing line @196.20'<N82 08'00"W
Have a good one, Mike
In the rotate command just type in i.e. 33d33'33"
I am new to Civil 3d 2013 and wanting to annotate land parcels with degree, minutes, and seconds. All I am getting is decimal degrees.
Any pointers would be most helpful.
You will need to change your style to use the right units for your bearings.
