Thread: Maximum Filename Length with ArcGIS
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,104
    Default Maximum Filename Length with ArcGIS
    Anyone have experience with importing dwg files into ArcGIS? Would you happen to know the maximum filename length?
    TN/KY Area
    1,640
    Default Re: Maximum Filename Length with ArcGIS
    In ArcView 3.x I think it was limited to 16 characters, in ArcGIS 10.1 I would think it would be a lot more. There are limits with the path so you may want to export the dwg to a shorter path to the ESRI files.
    2002-01
    jUSt Here (a lot)
    9,104
    Quote Originally Posted by Jmurphy View Post
    The path location I have NO control over. I am emailing a dwg file with a descriptive name of 62 characters. The recipient is requesting I rename the file with a shorter name and resend it to them. It is a bit of an unreasonable request, if you ask me.
    So, my question was to help me formulate an appropriate response other than some equally inappropriate language.
    2002-01
    jUSt Here (a lot)
    9,104
    I have since found out it is not an issue with the filename length. It is an issue that my dumb drawing would not project to the correct location in their GIS. Is there a step or setting needed with dumb drawings to project to the correct coordinates? I guess I should start a new thread.
    TN/KY Area
    1,640
    Your best bet is to mapexport to shp format your dwg. You're get less emails back from the GIS folks asking how to do this or that or what is this. When you export use the Multi-Class shp for type and it will create a folder of all the correct object types. For the attributes at least select the layer names.
  1. 2014: maximum alignment length?
    By cadtag in forum AutoCAD Civil 3D - Alignments
    Last Post: 2014-08-30, 08:35 PM
  2. Replies: 0
    Last Post: 2011-11-03, 07:10 AM
  3. What is the real maximum string length?
    By tufofi in forum AutoLISP
    Last Post: 2011-10-07, 04:49 AM
  4. Maximum Triangle Length - NOT
    By Spokes in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-03-17, 03:50 PM
