Thread: DWG Import into ArcGIS 10.1
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default DWG Import into ArcGIS 10.1
    I have a dwg that needs to be imported into ArcGIS. In doing so, the entities within the dwg are currently located in the correct coordinates. I have stripped out the coordinate information provided by Civil 3D.
    Is there a setting or step when importing into ArcGIS that needs to specify the coordinate system for the dwg?
    TN/KY Area
    1,640
    Default Re: DWG Import into ArcGIS 10.1
    Nope, You need to export to a shp file(s) from Civil3D if you want the coordinate system to beread. One thing you can do in ArcGIS is use the move/rotate/scale like you would in AutoCAD for an image, but ESRI doesn't know that dwg has a CS assigned.
    Edits: Just like AutoCAD the versions and add-on or modules as they call then, may play a difference on importing a DWG format file. If they have the full CAD module there is a reproject tool that can be used during the import or right after wards, look for the reproject tool in the help.
    2002-01
    jUSt Here (a lot)
    9,100
    Quote Originally Posted by Jmurphy View Post
    That's the problem. I don't even have access to the GIS software. I only have access to Civil 3D.
    Are you saying the reproject tool is in ArcGIS or AutoCAD?
    TN/KY Area
    1,640
    There is one in ArcGIS as long as they have the module for it. It's more of a "align" than the reprocect tools in Civil3d/Map3D.
  1. Help with ArcGIS for AutoCAD (Build 300)
    By unkleroy in forum AutoCAD Civil 3D - General
    Last Post: 2012-09-25, 03:42 PM
  2. ArcGIS for AutoCAD (Build 300)
    By unkleroy in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2012-09-24, 07:46 PM
  3. Does anybody use Esri ArcGIS?
    By GreyHippo in forum Software
    Last Post: 2005-06-29, 06:56 PM
  4. Using ArcGIS raw data with Map 3D
    By Tom Beauford in forum AutoCAD Map 3D - General
    Last Post: 2005-01-09, 02:24 AM
