Thread: SOME Fill Patterns Not Showing
    2012-07
    43
    Default SOME Fill Patterns Not Showing
    Hi Everyone,
    Some fill patterns aren't showing up when I draw a filled region such as gypsum plaster from the standard menu and none at all from the edit types menu. When the object is selected the pattern shows but when it's deselected nothing shows again. I've tried Course, Medium, Fine, changing line weight, transparancey, moving to front, moving to back but nothing works and I'm mystified. The drawings are 1 1/2" - 1'0" details if that makes any difference.
    Does anyone have any ideas on how to make this work?
    Thanks.
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: SOME Fill Patterns Not Showing
    Any chance you would have an element in front hiding it like a Masking Region?
    2012-07
    43
    No - because a) I tried using the send to back/send to front option and b) I switched between fill patterns without moving the region in various places and the same patterns show up or don't show up.
    2006-10
    Redding, CA
    430
    Is the color for the fill pattern set to white in the type properties of the filled region?
    2012-07
    43
    YES - you must have sent that to me by ESP! as I just figured that out and was about to post that info here!
    White lines on a white background by default settings - I wonder if there is a use for that..
  1. 2015: create/ convert hatch patterns (.pat) to revit fill patterns
    By jledgewood in forum Revit Architecture - Tips & Tricks
    Last Post: 2015-06-01, 11:48 PM
  2. Replies: 1
    Last Post: 2013-01-28, 12:52 PM
  3. Merge Line Styles, Line Patterns, Fill Patterns, Fill Types, etc.
    By cslaten78249688 in forum Revit Architecture - Wish List
    Last Post: 2011-10-20, 08:15 PM
  4. fill patterns
    By casparos in forum Revit Architecture - General
    Last Post: 2009-09-04, 05:05 PM
  5. Floor fill patterns showing through components
    By steve.70285 in forum Revit Architecture - General
    Last Post: 2004-10-30, 03:41 AM
