Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Help to Reduce Large Drawing Size
    2015-09
    420
    Default Help to Reduce Large Drawing Size
    Hello AUGI Members,
    We are having a problem with AutoCAD drawings received from a consultant. No matter what I try to reduce the file size I can only get it down to 6.5mb. I even deleted all of the elements on the drawing and the file was still over 6.1mb. Does anyone have any suggestions or recommendations to help resolve this problem. I would upload a sample drawing but the file size exceeds the forum limitations.
    Thank you for any assistance....!
    Regards,
    Vince
    2001-12
    St. Louis
    5,408
    Default Re: Help to Reduce Large Drawing Size
    Quote Originally Posted by vferrara View Post
    Hello AUGI Members,
    Regards,
    Vince
    Could you share what you've tried, so we're not telling you to repeat actions that have already not worked?
    My question would be, have you tried to use WBLOCK to export all of the entities to a new drawing file?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2015-09
    420
    Thank you Melanie,
    I have done the following actions to the drawings:
    - Purged
    - Audit
    - Lisp routine that deletes unnamed blocks starting with *U, *D and *A
    - Deleted layer filters
    - Lisp routine to remove $0$ from the layer names
    - Copy/clip and or -Wblock to clean file
    I even deleted all visiable objects on the drawing and did all of the above but the file size remains at 6.1mb.
    Regards,
    Vince
    2015-10
    158
    Ouch, sounds like you're needing to look at the more obscure stuff. The only one I can think of off hand is wipeouts; try a quick select, select all wipeouts, see if that shows anything. Once ran into this when a drawing had background masks for the main dimension style and they all got exploded (grumble grumble some people need to stay the h*** away from CAD...).
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Is there anything specific about this drawing that you need to keep in the original drawing? Why not wblock out the elements you need into a new drawing?
    2001-12
    St. Louis
    5,408
    Look at the OP's follow up, seems he's already tried that.
    Perhaps some 3rd party proxy element or something... dunno...
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2015-12
    2,095
    Massive quantities of annotation scales and/or empty groups? How about block references with nothing but invisible attributes? Large amounts of data (not graphical elements) attached at the drawing level?
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by Wanderer View Post
    But was the clean file the same size?
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Hello AUGI Members,
    Regards,
    Vince
    Can you attach a partial drawing here, if this is possible, then we can have a look?
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    - Purged
    Does that include stuff like zero length entities, empty strings and (most importantly) Registered Apps? I.e. did you run the command-line purge by prefixing the command with a minus sign:
    Command: -PURGE
    Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/All]: R
    Otherwise there might be some custom dictionaries added to the file. You could try finding these through my old DictEdit routine: http://sourceforge.net/p/caddons/cod...l/DictEdit.lsp
  1. 2011: How to reduce file size in AutoCAD
    By shanower_buet in forum AutoCAD General
    Last Post: 2013-03-14, 01:33 PM
  2. How can I reduce the size/polycount of my file?
    By comical_wenger in forum 3ds Max - General
    Last Post: 2010-10-19, 03:50 PM
  3. Reduce CAD file size before linking
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2007-10-12, 07:44 PM
  4. Reduce the File size...
    By Cyril Verley in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-06-28, 09:53 PM
  5. The drawing file size is large, but there is hardly anything in it.
    By Glenn Pope in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-17, 08:09 PM
