Guys,
So drawing up risers in ACAD is pretty simple with lines and shapes.
However with Revit, the only way I know how to manage a Riser is using either elevation or section views. With all that piping and ducts twisting, turning, and overlapping each other, it is hard to distinguish where all the lines are going and from which systems. Especially if you may have equipment hidden behind other equipment and piping parallel or colinear with each other.
Must I manually create my riser using detail lines which I had to do with my mechanical symbols list or is there an easier way using parametrics?
Help!
