Thread: Annotate Degrees minutes and Seconds on existing polygons
    2013-03
    2
    Default Annotate Degrees minutes and Seconds on existing polygons
    I am new to Civil 3d 2013 and have been unsuccessful in annotating existing polygons with degrees minutes second. The text always shows up as decimal degrees.
    Any help is appreciated.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Annotate Degrees minutes and Seconds on existing polygons
    You will need to either select a label style that displays the bearing in your desired format, or create/edit one to do so.
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Do you want all angles to report in degrees minutes second? If so, you can change the Angle setting in your Project Units on the Manage tab.
  1. Degrees, Minutes & Seconds
    By cad.33286 in forum AutoCAD General
    Last Post: 2013-03-02, 03:11 AM
  2. Input in degrees, minutes, seconds-how do I?
    By Lew in forum AutoCAD General
    Last Post: 2012-09-07, 02:22 PM
  3. Minutes & seconds in angles
    By al.dietz in forum AutoCAD Customization
    Last Post: 2009-04-16, 10:54 PM
  4. X annd Y co-ordinates in degrees, minutes & seconds
    By aaron.186517 in forum AutoCAD General
    Last Post: 2008-06-18, 03:11 AM
  5. How to enter Degrees Minutes Seconds?
    By Jason in forum Revit Architecture - General
    Last Post: 2004-12-02, 09:33 PM
