Hi all...
I need to make a dimangular informing the cords of center, angle 1 (first leader), angle 2 (second leader) and the length of dim. It's possible?
Hi all...
I have a code that makes a drawing. And must include an angular dimension this drawing. This quota will be inserted in objects "leader". The code can not prompt the user to select the objects. The code will automatically select.
I need this code below to work without the user having to select the objects. I need to include these objects in code. But I do not know how. And these lines are not objects, are "leader" that form a vertex.
(vl-cmdf "_.dimangular"
(entsel "\nPick a 1st line >>")
(entsel "\nPick a 2st line >>")
(getpoint "\nPick a text point >>")
Can you post a screen shot or an example of a drawing that you are trying to end up with?
Just to clarify, you have a program that makes the drawing and you want it to automatically put in an angular dimension?
Or is this angle just an annotation...you mention "leader"?
Can you post the code that "makes the drawing"?
