Thread: Shear Wall annotations
    2008-06
    Denver, CO
    179
    Default Shear Wall annotations
    Before I came to my current office, they predominantly used boxed text with arrows to denote the extents of their shear walls in wood framed buildings. I tried to make something a little more elegant / standardized and created a family with text box, and pull arrows. The problem is that I found is that I couldn't create a family with arrows that I could pull, as well as text that I can modify.. within an Annotation family. So I had to create a Generic Model family, with annotation elements that are only seen in Plan view.
    I'm wondering if anyone has some tips on how to make this perform better, or if you have any better ways of denoting your shear walls. I've attached a file with the annotation I'm using.
    Thanks,
    2007-01
    226
    Default Re: Shear Wall annotations
    I use a edit and make special dimension type to indicate shear walls, I like to show length of wall and also provide hatch pattern.
    2002-09
    Madison, WI
    5,688
    I've shaded the cut pattern before for shear walls. Looks nice, easy to denote....then we provide an elevation of the wall and typical cuts at corners and bar elevations for the field of it, along with any additional bars at openings.
  1. Shear Wall Indicator
    By orwake in forum Revit Architecture - General
    Last Post: 2008-09-18, 04:26 AM
  2. Shear Wall Openings
    By pjs_pape in forum Revit Structure - Wish List
    Last Post: 2007-07-10, 04:48 PM
  3. Shear Wall Family
    By Maximillian in forum Revit Architecture - General
    Last Post: 2007-03-27, 09:58 PM
  4. Shear Wall Schedule
    Last Post: 2005-08-28, 01:04 AM
  5. Shear wall symbol
    By john.s.algeo in forum Revit - In Practice
    Last Post: 2004-06-25, 02:11 AM
