So I'm making my way toward the end of the project,
Where now I have to create details in the Drafting View (Detail) section of the Project Browser
I saw in a video tutorial that in order create an isometric detail first you must create a Section View of the component. For the sake of this post my example is a Linear Plenum Box with duct connection.
Then, in the 3D View you orient to the Section isometrically
Finally you create your detail Sheet and drag the 3D view of the section into the drawing sheet.
Problem is the detailed lines does not snap into the 3D view. Understandable since it is simply a cropped view of the entire mechanical model.
Another problem is, if I decide I want to change to view scale,...well there goes all my line and text work, it's all screwed up!!! >
In ACAD all I have to do is scale all objects...is there a way to allow Revit to scale all my line and text and also if I can make the 3D isometric section view independent so I can snap lines to it?
And how do I make my crop view smaller? Takes all the space when I want right-click drag all my modeled items. you can see it in the image with the big white lined box. The smaller lines is my modeled lines
