Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: How do I insert a block using AutoLISP
  1. #21
    2012-06
    96
    Default Re: How do I insert a block using AutoLISP
    I envision the routine asking the user 7 digits (ex. 1234567) and by using those 7 digits I want to compile a string of the full address path.
    (setq drive "J:\\")
    (setq job (getstring "\nWhat is the job number (enter with no dashes)? "))
    (setq job1 (substr job 1 3))
    (setq job2 (substr job 4 4))
    ;;;(setq suffix (substr job2 ????? this is where I would need the function that would look up the suffix by using job2 (4567) variable
    (setq addresspath (strcat drive job1"\\"job2"-"suffix)
    ...then I would use the addresspath to insert the datum
    How do you envision this routine to operate? Do you want to request a project number combination? Or have the user browse for the necessary folder?
  2. #22
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Once you have the first part of the path, use the vl-directory-files function with the with the second part as a pattern to look for and filter for directories only.
    (setq drive   "J:\\"
          job     (getstring "\nSpecify job number (without dashes): ")
          prefix1 (substr job 1 3)
          prefix2 (substr job 4 4)
          project (vl-directory-files
    		(strcat drive prefix1)
    		(strcat prefix2 "*.")
    		-1
    You may have to adjust this code regarding the vl-directory-files function as I haven't tested it. My folder structure is completely different.
  3. #23
    2012-06
    96
    This code works perfectly
    I do have a question though...my project variable gives me the result in a ("text_text_text") format how do I remove the ()'s and make this line a piece of text?
    (setq drive   "J:\\"
    		-1
  4. #24
    2002-01
    jUSt Here (a lot)
    9,106
    the car function will give you the first element of that list.
  5. #25
    2012-06
    96
    The code works perfectly!!!
    I wanted to thank everyone who has helped me get this task accomplished.
    I have learned a lot...ironically this is what this user group is all about
  6. #26
    2018-05
    This post is old; however, the answer to your question is:
    1. set support file search path to the location of the block:
    2. open note pad. copy and paste the information (replace "ENTER BLOCK NAME HERE" with the name of the file you want to insert)
    (command "attdia" "0")
    (command "attreq" "0")
    (command "-insert" "ENTER BLOCK NAME HERE" "0,0" "1" "1" "0")
    (command "attdia" "1")
    (command "attreq" "1")
  1. Insert a Tool Palette Block While Editing a Block or Xref.
    Last Post: 2013-10-07, 04:53 PM
  2. Block Insert - Right Click Block Open Drawing
    By Texan1 in forum ACA Wish List
    Last Post: 2011-11-26, 04:38 AM
  3. AutoLISP function to get values of existing dynamic block insert
    By truevis in forum Dynamic Blocks - Technical
    Last Post: 2007-11-17, 04:34 PM
  4. Replies: 19
    Last Post: 2006-03-14, 05:06 PM
Tags for this Thread
