Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Is there a way to control underlay view?
  1. #11
    2008-06
    Denver, CO
    150
    Default Re: Is there a way to control underlay view?
    Can you create a plan view that only shows the walls (using filters), and then use that view as an underlay?
    Ryan Taube LEED AP
    ___________________
  2. #12
    2010-07
    115
    I finally got the second floor to overlap the 1st floor on my sheet. Not sure why it didnt work before. Thank you for all the help
  3. #13
    The ability to control graphics of an underlay is apparently a feature in 2014.
  4. #14
    2013-01
    10
    Quote Originally Posted by rtaube View Post
    Even better...You can isolate the walls of the underlay within the one view.
    For example: by creating a filter for all categories except Walls and creating a new custom Project Parameter to be used as a Filter Rule. You can call this Project Parameter "Level", make it instance and text, check all categories, and check OK. Now you can Filter By: "Level", equals, "Ground" (for example). Apply this filter and add it to the Visibility Graphics for your First Floor and uncheck the visibility tick box. Then select all families on the Ground Level (inc/exc walls) and type "Ground" in the parameter called "Level". Now your First Floor plan should only display the walls of the Ground Floor underlay.
    No need to create a separate plan view to align and realign, clutter up your browser, and use up memory.
  5. #15
    2010-07
    115
    Quote Originally Posted by rodger_soure349681 View Post
    Perhaps I am not understanding the function of Project Parameter and Visibility Graphics.
  6. #16
    2013-01
    10
    Quote Originally Posted by Bluefairy View Post
    The custom Project Parameter is simply used as a parameter which is common to all families (except walls in this case), of which there is otherwise no default parameter. WallUnderlay_Filter.PNG
    We can use this parameter to identify which families we want to filter. WallUnderlay_FamParameter.PNG
    The Visibility Graphics is where you add the filter to the view and toggle its visibility or graphic overrides. WallUnderlay_VG.PNG
  1. Underlay Visibility Graphics Control
    Last Post: 2012-09-11, 02:02 PM
  2. DWF Underlay Layer Control
    By MetalliCAD in forum DWF Viewer - Wish List (Closed)
    Last Post: 2006-12-06, 10:44 PM
  3. Layer control in DWF Underlay
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2006-06-07, 02:06 PM
  4. More Underlay Display Control
    By mlgatzke in forum Revit Architecture - Wish List
    Last Post: 2003-05-15, 12:23 PM
