Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: LISP NEEDED - Copy attribute and paste as single line text
  1. #11
    2012-05
    Planet Earth
    10
    Default Re: LISP NEEDED - Copy attribute and paste as single line text
    Quote Originally Posted by pbejse View Post
    To be on the clear, you are wanting to select a specific attribute in a block with as "crossing window" but not necessarily ALL the attdefs on that block?
    Let's say 'all visible ones which have values'. In other word, I am not interested in invisible and blank attributes.
  2. #12
    2019-01
    Sorry to resurect an old thread.... i think this LISP is close to what i am after, but i need to assistance in modifying the script.
    i need to copy and paste attributes within the same block. its the Revision part of a title block. this is part of 100+ visible and invisible attributes in 1 block called titleblock, i can not modify only fill in, as its a client's block. i have approx 2000 drawings i need revise up. in the layout below is how the attributes are set out. the latest/newest revision always being filled in in REV1 row, and all previous ones being copied or retyped in one row up.
    i have part of a script/method that can open, fill in the specific REV1 row from a CSV file, save, close and repeat for the next drawing. but i just cant get it to copy the rows up. the block name is always the same "tittleblock" and all the revision boxes are called
    REV12 REVDATE12 REVDRAW12 REVNOTE12 REVENG12 REVAPPRO12
    REV11 REVDATE11 REVDRAW11 REVNOTE11 REVENG11 REVAPPRO11
    REV10 REVDATE10 REVDRAW10 REVNOTE10 REVENG10 REVAPPRO10
    REV9 REVDATE9 REVDRAW9 REVNOTE9 REVENG9 REVAPPRO9
    REV8 REVDATE8 REVDRAW8 REVNOTE8 REVENG8 REVAPPRO8
    REV7 REVDATE7 REVDRAW7 REVNOTE7 REVENG7 REVAPPRO7
    REV6 REVDATE6 REVDRAW6 REVNOTE6 REVENG6 REVAPPRO6
    REV5 REVDATE5 REVDRAW5 REVNOTE5 REVENG5 REVAPPRO5
    REV4 REVDATE4 REVDRAW4 REVNOTE4 REVENG4 REVAPPRO4
    REV3 REVDATE3 REVDRAW3 REVNOTE3 REVENG3 REVAPPRO3
    REV2 REVDATE2 REVDRAW2 REVNOTE2 REVENG2 REVAPPRO2
    REV1 REVDATE1 REVDRAW1 REVNOTE1 REVENG1 REVAPPRO1
    What would be good is if it could copy row 11 and paste in row 12, copy row 10 and paste in row 11 and so on regardless if the attribute is empty or not, then delete the contents on row 1. that would get round all issues
  1. Replies: 3
    Last Post: 2012-01-19, 05:59 PM
  2. Replies: 0
    Last Post: 2011-09-23, 07:21 PM
  3. 2011: LISP, script or action recorder to copy-and-paste text into attributes?
    By simon.bannister in forum AutoCAD General
    Last Post: 2011-03-23, 11:55 AM
  4. turn single line of attribute text into two lines
    By JRBOURNE in forum Dynamic Blocks - Technical
    Last Post: 2009-12-23, 04:40 PM
  5. AutoCAPS for Single Line and Attribute Text
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2007-11-09, 06:55 PM
