Hello,
I am new to .net programming for AutoCAD.
In my system AutoCAD Civil 3D 2011 is installed and the OS is Windows XP.
As per the instruction in the "My First Plug-in Training" of autodesk, I did the installation of
- VS2008 Exprees,
- objectarx_2011 _wizard and
- autocad_2010-2012_dotnet_wizards
Now as I open visual studio and create a new project using the Autocad plugin, the following 2 errors are found in Error list.
- Type 'AutoCAD_VB_plug_in.My.MySettings' not defined.
- 'AutoCAD_VB_plug_in' is not a member of '<Default>'.
Why I am getting these errors? If I create a project without using Autocad plug-in, then everything is fine. So, there must some problem in the AutoCAD plugin? I have tried to uninstall the Autocad plug in and again re-installed. But i found the same errors when tried to create a new project using the plugin.
I have attached herewith the snap shot of the error.
Any help in this regard will be highly appreciated.
Thanks.
Rajesh
