Thread: Corinthian Column ?
    All AUGI, all the time BomberAIA's Avatar
    2003-05
    Boca Raton, FL
    652
    Talking Corinthian Column ?
    Does anyone have a Corinthian Column that will scale? The ones on the Modern Library & Revitcity won't. Thanks for the help.
    2003-09
    1,907
    Default Re: Corinthian Column ?
    This will scale in family, but not project. You might have to save it out to what specific height you need in your project.
    2013-03
    how do i scale this column. I am unable to do it. I go to edit type and the option to scale it is faded out.
    2001-12
    Irvine, CA
    7,567
    This thread is about eight years old now and the family contains a dwg file that is the geometry for the column. Back then we could associate the scale of a dwg file to a parameter and change it. Present day Revit seems to have lost the ability to alter it, at least it won't alter the nested dwg in this family. "Scaling" elements in Revit has always been managed by using parameters and has never been as easy as just "make it twice as big" unless you use parameters to respond to an input value like scale and then edit that value. The more things have to change in response to a single value the harder it can be to make the element scale. There have been some recent blog posts that take on the challenge of scaling a column faithfully.
    Post by Paul Aubin
    Post by Andy Milburn
    Marcello is doing a class on scaling families at RTC in July, called "Size Matters, Learn to Scale Families" in two parts, a lecture and a lab.
  1. Material cut from concrete column in elevated column schedule
    By khanson-3b in forum Revit Structure - General
    Last Post: 2011-04-10, 06:24 AM
  2. Graphical column schedule - issue with column location mark
    By brent.vanlelyveld in forum Revit Structure - General
    Last Post: 2009-05-21, 07:58 PM
  3. Graphical Column Schedule and slab/column intersection not show correct in GCS
    By jonas.152865 in forum Revit Structure - General
    Last Post: 2008-07-16, 06:58 AM
  4. Column Grid Lines and Shifting Column Grids
    By .chad in forum ACA General
    Last Post: 2007-11-02, 03:42 PM
  5. corinthian pilaster
    By Revit_Victim in forum Revit Architecture - Families
    Last Post: 2007-10-25, 07:31 PM
