Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Disappearing Support File Search Paths
    2006-03
    San Cristobal, Guatemal
    439
    Default Disappearing Support File Search Paths
    Could some help with my Disappearing Support File Search Paths. I add the File Search Paths, save my work space then save profile. The next day when I open ACAD mechanical the added File search paths are missing. I currently have the switich to open <<ACADMPP>> which is the same profile that I save to. Any thoughts or suggestions? Thanks.
    2009-11
    5,714
    Default Re: Disappearing Support File Search Paths
    Perhaps these are being reset to a pre-defined configuration via Acad.lsp? This is how I manage the Profile (mostly).
    Computer Specs:
    2006-03
    439
    Quote Originally Posted by BlackBox View Post
    Thank you for such a quick reply. I think I understand about having a lisp reset, but I believe I do not have any such lisp loading. Perhaps something else?
    2009-11
    5,714
    In my limited experience, this file (Acad.lsp) is rarely used unintentionally to modify such Profile properties, and is usually implemented by a CAD Admin/Manager as part of your setup.
    I'm not sure what your working environment is in that regard, but as Acad.lsp is a user-defined file that must reside within the SFSP, you can use this to find out if you even have one loading:
    (findfile "acad.lsp")
    Separately, you mentioned specifying a specific profile from your application icon's target property (using /p startup switch); are there any other switches being used that might load something else?
    Computer Specs:
    2006-03
    439
    I am not sure how to use this code; save as a lsp file and ap load or something else? Please advise
    I do have a startup script that loads custom menu bars and then saves the template file as when first opened, but nothing else. Perhaps something else? Thanks
    2009-11
    5,714
    Quote Originally Posted by Darren Allen View Post
    The code is LISP, and can simply be copied + pasted to the command line. If the file is found, the code will return the file path location, otherwise Nil if not found.
    You might also consider searching for "acad.fas" and "acad.vlx" as well.
    SFSP do not change themselves, if you're experiencing a repeated 'reset' to your SFSP, then something is causing it. More information is needed in order to better help you.
    Computer Specs:
    2006-03
    439
    The code is LISP, and can simply be copied + pasted to the command line. If the file is found, the code will return...You might also consider searching for "acad.fas" and "acad.vlx" as well.
    This is what I found
    Attachment 89633
    Please advise?
    2015-12
    2,095
    I really hate to suggest this, but I've seen this behavior with "bad" installs (e.g. user doesn't have rights to modify registry, excessive UAC settings, corrupt Win user profile). Search paths are stored under the AutoCAD profile in the registry, so any attempted changes don't stick.
    2009-11
    5,714
    I've thankfully never seen such a scenario... Would the user be able to set the paths at all if that were the case, rather than setting them, and loosing them at next session start?
    Computer Specs:
    2006-03
    439
    Please direct me in getting the more info for your assistance. Thanks you
  1. Trouble with Support File Search Paths
    By JGARZA0422 in forum AutoLISP
    Last Post: 2013-07-21, 03:45 PM
  2. Replies: 30
    Last Post: 2013-07-10, 03:13 PM
  3. 2011: Windows Env Vars in Support File Search Paths
    By mcnamac in forum ACA General
    Last Post: 2011-03-03, 05:54 PM
  4. Easy way to set-up Support File Search Paths
    By joeswantek in forum AutoCAD Customization
    Last Post: 2006-07-11, 08:21 PM
