Thread: 3D View Print Problem
    2009-01
    68
    Default 3D View Print Problem
    I have been having bad results printing 3D views to pdf and dwf. I attached the screen shot of the sheet I have set up in Revit. I also attached a dwf version of that sheet (update - had to do a screen shot because the dwf was too large to upload). You can see the 3D views are choppy or significant pieces of the view missing. This has been really hit or miss over the past month for me.... sometimes the 3D view prints fine, but most of the time I get bad results. Can someone advise and let me know if there is some way I can tweak print settings to get decent pdf or dwf output?
    Chesterfield, MI
    405
    Default Re: 3D View Print Problem
    Do you have Hardware Acceleration enabled? I have seen similar issues and enabling Hardware Acceleration has helped.
    2009-01
    68
    I didn't have hardware acceleration enabled. That worked! I think I had a prior technical issue where it was recommended I turn that off... I think it was the windows being visible through walls in 3D, but I believe that has been fixed by a service pack.
    Thank you.
  1. Print the View Name?
    By Revit MEP DR in forum Revit MEP - General
    Last Post: 2012-01-19, 05:54 PM
  2. How do I print a 2d DWG of a 3d view?
    By 3dway in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-07-08, 04:18 PM
  3. Oce Print/plotter Problem
    By jmedley in forum Hardware
    Last Post: 2008-01-10, 06:41 AM
  4. DWF Print Problem
    By dsw98 in forum Revit Architecture - General
    Last Post: 2007-03-07, 07:52 PM
  5. Perspective Print Problem
    By stuntmonkee in forum Revit Architecture - General
    Last Post: 2005-03-17, 05:34 PM
