Thread: section heads different colours
    2015-09
    Sebringville, Ontario, Canada
    64
    Question section heads different colours
    I am not sure when or why this has changed but why does a section head appear blue on one end and black on the other. My secton marks use the "Section Head Fliled" for both the head and tail, but one is blue and one is black. I would prefer both to be blue,but I can see no way to change it. Any suggestions?
    I could stop if I wanted to zanzibarbob7's Avatar
    2004-08
    Wayne, ME
    444
    Default Re: section heads different colours
    The Head and the Tail are separate families, which you and find under annotations. Right click on either and edit. What you have are filled regions, there you can change the colors to your liking. Good luck.
    380
    The blue objects are links, you can double click them to go to that view. On building sections, only one of the heads is a link. They should all print black, regardless of the link.
    2011-12
    6
    Had the same thing happen to me. I thought it might be related to the fact that I changed the text in the section head. (Maybe it is, maybe it isn't) Also, I like Building Sections to have the circles with arrows at both ends, so I changed the type so that I wouldn't have to cycle through the tail every time. All this lead me to believe that I must have messed something up.
    Then, for kicks I decided to see what would happen if I simply cycled through the tail ends and voila, the black section head turned back to blue. Problem solved. Oddly however, I had to cycle through the symbol in each view that showed the section symbol (ie: Elevations & Sections) ... go figure.
  1. Replies: 2
    Last Post: 2014-04-13, 07:56 AM
  2. Section Heads
    By Happyunited in forum Revit MEP - General
    Last Post: 2011-07-08, 09:30 AM
  3. Section Heads
    By momarch in forum Revit Architecture - General
    Last Post: 2011-03-19, 04:07 PM
  4. Section Heads/SIM
    Last Post: 2005-11-11, 01:33 AM
  5. section/ callout heads
    By rjjlee in forum Revit Architecture - Wish List
    Last Post: 2004-12-14, 02:12 AM
