Results 1 to 1 of 1
Thread: CP22-3L: Changing Hundreds of Drawings in a Hurry
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CP22-3L: Changing Hundreds of Drawings in a Hurry
    Instructor: Dan Abbott
    Class Description: You can make the same change to hundreds of drawings with a single command -- that is, if you know how to write AutoCAD scripts, Windows batch files, and AutoLISP programs that work together. Perhaps you need to redefine a block definition in every drawing file (the company title block changed again!), or reduce the file size in all of your archived drawings, or create individual drawing files from each block definition in a group of drawings. You can complete these and other tasks with an AutoLISP program. In this hands-on lab, you will learn how to sit back and watch the computer do all the work for you.
  1. CP14-1L: Changing Hundreds of AutoCAD Drawings in a Hurry
    Last Post: 2013-04-17, 04:16 AM
  2. CP12-3L: Changing Hundreds of AutoCAD Drawings in a Hurry
    Last Post: 2013-04-17, 04:14 AM
  3. CP34-1L: Changing Hundreds of AutoCAD® Drawings in a Hurry
    Last Post: 2013-04-10, 02:38 AM
  4. CP22-4L: Changing Hundreds of AutoCAD® Drawings in a Hurry
    Last Post: 2013-04-10, 02:24 AM
