Results 1 to 7 of 7
Thread: Slow Layer Manager and Layer Pulldown
    I could stop if I wanted to bskripac's Avatar
    2002-04
    Columbus, Ohio
    212
    Default Slow Layer Manager and Layer Pulldown
    In AutoCAD 2005 the Layer Manager and Layer Pulldown are taking extremely long to open, sometimes over a full minute. I looked on the AutoCAD Knowledge Base and found an answer but it is not really helping. Service Pack 1 is installed and there are no layer filters being used. Those were the fixes that were mentions. Anybody have any other ideas?
    13,499
    Default Re: Slow Layer Manager and Layer Pulldown
    Quote Originally Posted by bskripac
    Hi
    Are there Layer Filters present within the drawing file (ie not being used, but present never the less)?
    How about Layer States?
    Have a good one, Mike
    2002-04
    Columbus, Ohio
    212
    The only filter in the is from the one drawing that is xreferenced in. That file also has four layer states assigned to it through the Layer State Manager. There are a total of 246 layer in the file also. None of these things caused a problem in 2000i before we upgraded, that is what is weird about it.
    2005-01
    78
    Im having the same problem with some blocks that contain only one layer. Anyone want to have a look?
    2005-01
    78
    Please disregard, I found the cause the of the problem.
    13,499
    Hi
    Can you please share the cause of the problem and fix (could prove to be useful to others).
    2005-01
    78
    The block has about 100 or so layer filters attached to it. I purged them by using wblock.
  1. Layer Properties Manager slow to open completely
    By perry_kostanich in forum AutoCAD General
    Last Post: 2008-07-22, 08:58 PM
  2. Slow Layer Manager and Deleting Filters
    By n3xutl in forum AutoCAD LT - General
    Last Post: 2007-11-19, 12:24 PM
  3. Slow Layer Manager
    By jetman in forum AutoCAD General
    Last Post: 2005-07-29, 03:42 AM
  4. Layer Manager & Layer drop down are slow to open.
    By Glenn Pope in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-17, 05:01 PM
  5. Layer Manager slow to open
    By cbs.80861 in forum AutoCAD General
    Last Post: 2005-01-15, 10:37 PM
