Thread: inches instead of feet and inches
    2001-07
    488
    Default inches instead of feet and inches
    How do I change the reading of a dimesion to read 12" instead of 1'-0"
    I don need this in all dims only in the ones that are too small to fit the whole text.
    thanks
    AUGI Addict christopher.zoog51272's Avatar
    2003-04
    Cinnaminson, NJ / NYC
    1,096
    Default Re: inches instead of feet and inches
    you can't do it mid-string in a single string. But you can create a new "inches" style for the portion that needs to be in inches. (duplicate current style, override units to read in fractional inches)
    Chris
    SOM | New York
    2003-05
    5,153
    And once you've done as Chris says, just slide the new inches style dimension over the old and it will snap in place and (hopefully) hide the old dimension if set to opaque.
    2013-04
    3
    dimension style<under primary units select fractional<suffix = "
  1. BOP in feet-inches-fractional
    By pauljordan in forum AMEP General
    Last Post: 2009-05-04, 02:57 PM
  2. Inches versus Feet
    By khamm in forum Revit Architecture - Wish List
    Last Post: 2007-06-12, 04:49 PM
  3. Dim Style from feet to inches
    By sherflor in forum AutoCAD General
    Last Post: 2006-02-08, 09:44 PM
  4. Feet vs Inches
    By CADMama in forum Revit Architecture - General
    Last Post: 2006-02-01, 04:30 PM
  5. Converting feet to inches
    By lillian.twining in forum AutoLISP
    Last Post: 2005-05-12, 06:33 PM
