Thread: Revit 2013 Crashes on startup- without any error.
    2013-04
    Default Revit 2013 Crashes on startup- without any error.
    Alright, so I have revit 2013 installed on my laptop for school. I've been searching on the web for the past week or so to see if there is any remedy for this issue. So two weeks ago I go to start up Revit, and it'll launch and load
    all the way to the start screen, then it'll just close no error, nothing, I have tried everything and can't seen to figure out what's going on.
    I have a Alienware that is built but pretty good the specs. are ( i7-3840QM, 256 gb solid state HD, 16 gb of 1600MHZ of RAM, 1 GB GDDR5 NVIDIAGeForce GT 650M with Optimus )
    any help is much welcomed..
    thanks
    Chris
    2015-12
    16
    Default Re: Revit 2013 Crashes on startup- without any error.
    Did you recently add Vasari to your computer? I had that problem recently, Revit started crashing once I installed Vasari. after removing it, everything went back to normal. Too bad, since I really like the wind tunnel tool it has, among others, that aren't included in Revit yet.
    2005-07
    Somewhere in the BIM world
    3,792
    Check if you ran any Windows Update since then.
  1. 2013: C3D 2013 SP1: Fatal Error on startup
    By MLS at ASE in forum AutoCAD Civil 3D - General
    Last Post: 2013-04-18, 10:39 AM
  2. 2013: Revit 2013 Crashes opening a view
    By bmyrum in forum Revit Architecture - General
    Last Post: 2013-04-03, 01:15 PM
  3. Revit 2013 upgrade yet? - softaware stability, crashes & bugs
    By andrewharle in forum Revit Architecture - General
    Last Post: 2013-01-08, 09:10 AM
  4. Replies: 1
    Last Post: 2008-10-11, 05:25 PM
  5. Revit 2008 Startup Error - Server Busy
    By mibzim in forum Revit Architecture - General
    Last Post: 2007-07-10, 12:16 AM
