Thread: How to change Ceiling Fixture to Roof-mounted fixture?
    2003-09
    California
    400
    Default How to change Ceiling Fixture to Roof-mounted fixture?
    I molded my ceiling using a roof (so that I could use more than one slope). Now I want to place some ceiling-mounted fixtures into my model. Is there an easy way to change a ceiling-mounted light fixture so that it will attach itself to the bottom of the roof?
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,532
    Default Re: How to change Ceiling Fixture to Roof-mounted fixture?
    not really. you can cut and paste geometry into a new roof based family, but you'll have to redo the parameters. There has been a lot of discussions on this if you search the forum...
    Steve
    2003-09
    California
    400
    Thanks for the replay. I guess I'll remake the roof to be an actual ceiling.
    100 Club studioCJF's Avatar
    2003-08
    Chicago
    106
    hdjohnson
    I don't know if this helps... but I made a roof that is concrete (pre-cast planks) and is exposed on the underside with no ceiling. I created a ceiling type using the "Basic Ceiling" and assigned the "Material" layer to "Finishes-Interior-Paints and Coatings" set to "Accurender/Solid Colors/Clear Sealer" and set the height to the under side of structure/roof. I was then able to place lights. As far as your ceiling with multiple slopes... I guess you could make a ceiling panel for each of the sloped areas?
    Clark
    (...still teaching this dog new tricks...)
    studioCJF
    2003-09
    California
    400
    Quote Originally Posted by cjfell
    hdjohnson
    Clark
    Thanks for the information. I'll have to try that later. I ended up just making a number of different ceilings and then joined them together.
  1. Generic Light Fixture Familys vs Project Specific Fixture Data
    By AnnieJ115 in forum Revit MEP - General
    Last Post: 2011-09-28, 05:37 PM
  2. Linked fixture not cutting ceiling
    By KGC in forum Revit Architecture - General
    Last Post: 2011-01-11, 07:11 PM
  3. Exterior wall mounted light fixture
    By wse1 in forum Revit Architecture - Families
    Last Post: 2008-05-12, 04:27 PM
  4. Wall Mounted Fixture
    By nsinha73 in forum Revit Architecture - Families
    Last Post: 2007-01-10, 04:15 AM
  5. ACT Ceiling & Light Fixture Issues
    By rookwood in forum Revit - Rendering
    Last Post: 2005-07-16, 01:18 PM
