Results 1 to 1 of 1
Thread: MA22-3: Creating and Using Autodesk Inventor® iParts and iMates
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default MA22-3: Creating and Using Autodesk Inventor® iParts and iMates
    Instructor: Bill Fane - British Columbia Institute of Technology
    Class Description: Inventor, especially Release 10 and later and the Professional variants, includes a huge library of stock components such as gears, bearings, threaded fasteners, and so on. Even so, it is not possible for it to include your "stock" parts when it comes out of the box. Most companies have a series of component parts that are unique to their product line, but are used in various sizes and configurations depending on the particular model or variant being built. A simple example might be a basic shaft that is made in a variety of user-specified lengths. This presentation will show you how easy it is to set up an iPart factory. Now, your designers will be able to quickly and easily pick a type of component from your library, and then specify details such as size, capacity, and so on. The iPart factory will then generate the specific part. iParts can include iMates, so that the iPart components "automatically" attach themselves properly as they are inserted into an assembly.
  1. MA104-3: Creating and Using AutoCAD Inventor iParts and iMates
    By Autodesk University in forum Manufacturing
    Last Post: 2014-12-01, 03:21 AM
  2. MA22-2: Getting the Most from Autodesk Inventor® Templates
    Last Post: 2013-04-17, 04:58 AM
  3. MA32-4: Creating and Using Autodesk Inventor iParts and iMates
    Last Post: 2013-04-17, 04:32 AM
  4. MA22-4: Animating Autodesk Inventor® Parts in Autodesk® VIZ
    Last Post: 2013-04-10, 01:48 AM
  5. MA22-3: What's New in Autodesk Inventor® ?
    Last Post: 2013-04-10, 01:35 AM
