Results 1 to 1 of 1
Thread: GD35-5: Advanced DWF™ Publishing from AutoCAD®: Tips and Tricks
    2012-11
    3,030
    Default GD35-5: Advanced DWF™ Publishing from AutoCAD®: Tips and Tricks
    Instructors: Brian Mathews - Autodesk, Inc.
    Class Description: In this session, you will learn the advanced tricks for publishing DWF data from AutoCAD including:
    • When to use the Sheet Set Manager vs. the Publish command
    • How to publish 3D data to DWF
    • How to publish AutoCAD Block attribute data to DWF as object properties
    • How to securely filter what data is published to DWF
    • Defining page templates for DWF
    • Using page setup overrides for DWF
    • How to enable merge control support with DWF
    • Publishing DWF automatically to Autodesk Buzzsaw
    • How to leverage other Sheet Set Manager features such as properties and sheet indices.
  1. MP214-1L: AutoCAD MEP 2010 Advanced Tips and Tricks
    By Autodesk University in forum MEP Design and Engineering
    Last Post: 2014-12-01, 03:25 AM
  2. GD311-4: DWF Publishing from AutoCAD: Tips and Tricks
    By Autodesk University in forum General Design
    Last Post: 2013-05-06, 01:34 AM
  3. GD35-3: AUGI® Tips and Tricks
    Last Post: 2013-04-17, 04:43 AM
  4. GD35-3: Tips and Techniques for AutoCAD® 2005
    Last Post: 2013-04-10, 02:16 AM
  5. 2012: AU Tips & Tricks for Advanced Graphics - teaser.
    By SCShell in forum Revit Architecture - Tips & Tricks
    Last Post: 2011-12-10, 01:25 AM
