I just slightly tweaked this code,
see if this will works
;; original code by VVA
(defun make_mleader_style (mleaderstylename
textcolor
leadercolor
adoc
mldrdict
newldrstyle
objcolor
(vl-load-com)
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(setq mldrdict
(vla-item (vla-get-dictionaries adoc) "ACAD_MLEADERSTYLE")
) ;_ end of setq
(setq newldrstyle
(vlax-invoke
mldrdict
'addobject
mleaderstylename
"AcDbMLeaderStyle"
) ;_ end of vlax-invoke
) ;_ end of setq
(setq objcolor (vla-getinterfaceobject
(strcat "AutoCAD.AcCmColor."
(substr (getvar "acadver") 1 2)
) ;_ end of strcat
) ;_ end of vla-getinterfaceobject
) ;_ end of setq
(vla-put-colorindex objcolor textcolor)
(vla-put-textcolor newldrstyle objcolor)
(vla-put-colorindex objcolor leadercolor)
(vla-put-leaderlinecolor newldrstyle objcolor)
(foreach item
(list
'("AlignSpace" 4)
(list
"ArrowSize"
(fix (/ (vla-get-arrowsize (vla-item mldrdict "Standard"))
2
) ;_ end of /
) ;_ end of fix
) ;_ end of list
'("BitFlags" 0)
'("BlockConnectionType" 1)
'("BlockRotation" 0.0)
'("BlockScale" 1.0)
'("BreakSize" 0.125)
'("ContentType" 2) ;mtext
'("Description" "My Style Description")
'("DoglegLength" 1.25)
'("DrawLeaderOrderType" 0)
'("DrawMLeaderOrderType" 1)
'("EnableBlockRotation" -1)
'("EnableBlockScale" -1)
'("EnableDogleg" -1)
'("EnableFrameText" 0)
'("EnableLanding" -1)
'("FirstSegmentAngleConstraint" 0)
(list "LandingGap"
(vla-get-landinggap (vla-item mldrdict "Standard"))
) ;_ end of list
'("LeaderLineType" 1)
'("LeaderLineTypeId" "ByLayer")
'("LeaderLineWeight" -3)
'("MaxLeaderSegmentsPoints" 2)
'("ScaleFactor" 1.0)
'("SecondSegmentAngleConstraint" 0)
'("TextAlignmentType" 0)
'("TextAngleType" 0)
'("TextHeight" 1.5)
'("TextLeftAttachmentType" 4) ;original 3
'("TextRightAttachmentType" 4);original 3
'("TextString" "Default\\PText")
'("TextStyle" "STANDARD")
) ;_ end of list
(vlax-put newldrstyle (car item) (cadr item))
) ;_ end of foreach
newldrstyle
) ;_ end of defun
;; Test
(defun c:msv (/ *error* ms)
(vl-load-com)
(defun *error* (msg)
(command "_undo" "_e")
(if (and msg
(not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
) ;_ end of and
(princ (strcat "\nError: " msg))
) ;_ end of if
(princ)
) ;_ end of defun
(command "_undo" "_be")
(if (vl-catch-all-error-p
(vl-catch-all-apply
'(lambda ()
(setq ms (make_mleader_style "MyCoolstyle" 5 72));change "MyCoolstyle" and colors to suit
) ;_ end of lambda
) ;_ end of vl-catch-all-apply
) ;_ end of vl-catch-all-error-p
(alert "Problem creating Mleader Style")
(setvar "CMLEADERSTYLE" "MyCoolstyle");change "MyCoolstyle" to suit
) ;_ end of if
(vl-catch-all-apply
'(lambda () (vla-put-arrowsymbol ms "_Origin2"));; existing arrow block in the drawing
(not
(vl-catch-all-apply
'(lambda () (vla-put-arrowsymbol ms acarrowdefault))
) ;_ end of not
) ;_ end of if
(princ)
) ;_ end of defun
