Thread: Stationing
    2013-02
    2
    Default Stationing
    I found a routine that I would like to use that does what I need it to do except that it puts numbers
    at vertices but I need it to label text at measured distances in civil engineering stations instead
    starting with 0+00. Can anyone figure out how to code it?
    (Please see attached)
    Thanks
    2009-11
    5,719
    Default Re: Stationing
    For anyone else interested in helping, here's my response from the OP's duplicate thread:
    Quote Originally Posted by BlackBox
    Since you're not using Civil 3D (which does all of this for you), why not just setup a typical "Station" block, and insert using the Measure Command, and be sure to select 'Yes' for 'Align to Object' prompt? unsure.gif
    Computer Specs:
    2001-12
    St. Louis
    5,407
    Thanks!
    I've also moved this from the Freestyle forum to the programming forum. Cheers.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Cairo - no, not Illinois
    5,069
    There are a lot of routines out in the wilds of the world wide web to do statining in CAD. Might also try searching on 'chainage' as an equivalent term.
    2006-04
    466
  1. Stationing Autolisp routine
    By aaronic_abacus in forum AutoLISP
    Last Post: 2020-03-06, 11:50 AM
  2. 2013: Alignment Stationing is in inches
    By mjw561381425 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2014-07-30, 05:27 PM
  3. 2014: Problem with alignment stationing
    By kwielin436245 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2014-01-16, 09:46 PM
  4. Stationing labels
    By robertlynch in forum AutoCAD LT - General
    Last Post: 2010-03-09, 03:30 PM
  5. Expressions for stationing
    By mhs50000 in forum AutoCAD Map 3D - General
    Last Post: 2007-10-29, 02:46 PM
