Thread: Read File from text file to restore settings
    2006-10
    3
    Default Read File from text file to restore settings
    Hello,
    I have lisp routine that will read settings from a text file and set the values in Autocad. If file doees not exist it will prompt with a message.
    Never mind, found the problem.
    2009-11
    5,719
    Default Re: Read File from text file to restore settings
    Is this related to your other thread?
    Computer Specs:
  1. Replies: 4
    Last Post: 2015-02-26, 11:46 AM
  2. How to restore broken DWG file?
    By DonaldMParnell684104 in forum CAD Management - General
    Last Post: 2015-01-14, 01:08 PM
  3. open and read text file
    By bandent in forum AutoLISP
    Last Post: 2010-04-15, 08:46 PM
  4. Read / Write To Text File
    By caddog71 in forum VBA/COM Interop
    Last Post: 2008-05-27, 06:40 PM
  5. read-line loop column text file
    By dukwing16 in forum AutoLISP
    Last Post: 2006-05-13, 05:22 PM
