Thread: object viewer
    Default object viewer
    Hello,
    I use autocad mep 2013 and when I try to use 'object viewer' there doesn't appear the command in right mousse command (3d object selected). In command line : Command: OBJECTVIEWER
    Unknown command "OBJECTVIEWER".
    I looked in help and there is write that: '...The Object Viewer can be started from different locations in the software.'.
    If I try on different computer (same drawing, mep 2013), I can use object viewer.
    Or do you know where is the location on tools pallete ?
    Can You help me with this ?
    Thank You
    2001-12
    St. Louis
    5,407
    Default Re: object viewer
    Quote Originally Posted by ala.balaportocala256381 View Post
    Hello,
    Thank You
    Unknown command would indicate a problem within the program (or that someone has undefined the command).
    My first suggestion would be to do a 'repair' install on your program.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2003-03
    Philadelphia, PA
    2,392
    Do any other MEP commands work? If not, you may have started AutoCAD MEP with an "as AutoCAD" profile, which would not have any of the AutoCAD MEP commands loaded (such as ObjectViewer). If you are not in such a profile, then Melanie's suggestion would be my next step.
    2001-12
    St. Louis
    5,407
    Quote Originally Posted by dkoch View Post
    Oh, good advice, David, I didn't even think about that... I go back and forth between MEP and Vanilla and sometimes forget which commands (like this one) are not available in vanilla.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Replies: 0
    Last Post: 2010-04-14, 11:29 AM
  2. Object Viewer Display Issue
    By raymond.p.remmers in forum AutoCAD Civil 3D - Corridors
    Last Post: 2009-03-10, 04:08 PM
  3. BS Object Viewer, but with Acadm 2005?
    By jnewell in forum AMEP General
    Last Post: 2004-11-15, 11:29 PM
  4. BS Object Viewer (Besides BS2005 =-)
    By MMccomb in forum AMEP General
    Last Post: 2004-11-10, 07:23 PM
