Thread: MEP Assemblies?
    Post MEP Assemblies?
    Hi All,
    I am currently working on a modular plant room of which we hope to use revit MEP.
    One of our Arch / Structural Revit users has shown me the assemblies feature and this would be perfect for what i need to produce however it doesn't seem to work for MEP components.
    does anyone know why this doesn't work for MEP and is there a work around?
    cheers
    2004-06
    Port Moody, BC
    349
    Default Re: MEP Assemblies?
    Most model elements (walls, floors, roofs, family instances, parts, and so on) can be included in assemblies. The following elements cannot be included:
    Annotations and detail items
    Assemblies and elements that are already part of another assembly
    Complex structures (trusses, beam systems, curtain systems, curtain walls, stacked walls)
    Elements in different design options
    Groups
    Imports
    Images
    Links or elements in a link
    Masses
    MEP-specific elements (ducts, pipes, conduits, cable trays and fittings, HVAC zones)
    Model lines
    Railings that have a continuous top rail or handrail defined in the railing type properties
    Rooms
    Stairs created by components (stairs created by sketch can be included)
    Structural loads, load cases, and internal loads
  1. Transition between two assemblies
    Last Post: 2013-10-30, 07:50 PM
  2. Assemblies
    By andyhoman1550505 in forum Revit Structure - Families
    Last Post: 2012-04-30, 05:47 PM
  3. Ifc export from assemblies?
    By m.knutsson714642 in forum Revit Structure - General
    Last Post: 2009-02-10, 09:38 AM
  4. Layers in assemblies
    Last Post: 2009-02-09, 04:11 AM
  5. Ifeatures in Assemblies
    Last Post: 2006-05-06, 03:37 PM
Tags for this Thread
